ISIS could not create and initialize the specified thread lock. The process failed to start as a result.
This indicates that the switch is running low on memory resources. Reducing the size or complexity of the switch configuration may alleviate this issue. The ISIS process will need to be restarted. If the problem persists capture "show tech" output and contact customer support.
Error
ISIS failed to initialize thread lock: %lockName%
| Name | Type |
| lockName | String |
